Is anyone else out there having problems with Dallas 80c390 contiguous mode? We are using Keil c51 version 6.14 and the PK51 development system. (Lx51 linker, Ax51 assembler) I am a little bit confused about the 512K option in the Options/Target box. The only information I have found about it is the text that comes up with the help button (?) (no mention of it in the C51 book under the ROM command.) This button says: "C51 generates ACALL and AJMP instructions with 19 bit address using the contiguous mode of the Dallas 390 and variants. The maximum program size may be 512 K bytes" Does anyone know what this is intended for? We would like to be able to run in 24(22) Bit Paged addressing mode, but it doesn't look like this is the setting that will accomplish this. As far as I can tell, (although it isn't explicitly stated, as far as I have found) the Keil compiler does not support the 24 bit paged addressing mode of the Dallas 390. (IE ACON AM1=0 and AM0=1) Does anyone know if this is in fact true? Another problem we have been having with C51 is with the SEGMENTS wildcard (*) and trying to locate an entire file within a specific memory block. Does anyone know of an in-circut emulator that supports the 24 bit contiguous mode of the Dallas 390 (not the 22 bit paged)? Thanks
Dallas 390 Mode is realative new. More information will be available in the upcoming V6.20
What is the tentative release date for Version 6.20? Thanks
The release is planned for the coming week. If you need it now, please send your serial number via email to support.intl@keil.com.
I am using version PK51 version 7 and I am also experiancing problems, with the Dallas 390 continous mode. Are you still experiancing problems ? Are you still using version 6.2 ?
Yes I am still having some problems but our system is up and running. After an earlier update I was able to get the SEGMENTS wildcard to work properly. I think this was a bug in the linker. I am using LX51 v3.2g. I am using C51 version 7.0 beta 1. My software agreement expired just before 7.0 was released. I am using the MetaLink emulator for 24 bit contiguous emulation. After numerous problems I was able to make this work, but it will not run at our target speed (limited to 16 MHz I believe.) I have never resolved some of the initial problems with the FVAR command. I changed the memory map so that I did not need to use FVAR. I defined one memory range as HDATA and used the far keyword for all variables I wanted in this memory range. I am currently limited to 64k of base memory, as I have not gotten the FVAR command to work. I have not tried this with version 7.0b yet. Hope this helps Dan
Most of my problems appear to be related to the xdata and pdata C stacks when using reentrant functions, causing accesses to unavaiable memory. I also had a problem with linker which keil resolved for me, this seamed to the linker occassionly mixing up ACALLs and LCALLs when performing optimisation. I am using the FVAR command to access our hardware which is mapped at 0x300000 and above. I am actually currently using PK51 version 7.02b, with an extra fix for the ACALL/LCALL linker problem.
