I explain you my problem : i have a Banking Code Bank, The first bank is the common, the second bank 1 and the third is Bank2, when I compile the project two files hex is generated h01 and h02 , the two files are the same common code. . It is mapped as following: Common 0x0000-0x3FFF Bank1 0x4000-0x7FFF Bank2 0x4000-0x7FFF Actually my problem, is the download in the PROM for execution of my code with the bound-out in stand-alone. How can I download the files hex in PROM to execute and access the bank 2. I thank in advance for your answer . Best Regard Laila AHDDAR
