Identify Storage of String Literals in Mapfile
Is it possible to identify the storage of String Literals from the mapfile?
I asume they will be in the ?CO? segment for the module?
eg,
void func( void )
   code unsigned int NumConst = 1;
   printf( "NumConst = %u", NumConst );
Will both the integer constant NumConst and the string literal "NumConst = %u" be stored in the same ?CO? segment, or will they be listed separately in the map?
  • The Storage of string literal will be placed in just one ?CO? segment inside your MAP file, ( ?CO?your_source_filename Ex.:
    MEMORY MAP OF MODULE:  C:\EMBEDDED\EMUL251\MAPTEST (MAPTEST2)
    START     STOP      LENGTH    ALIGN  RELOC    MEMORY CLASS   SEGMENT NAME
    000000H   000007H   000008H   ---    AT..     DATA           "REG BANK 0"
    000008H   00001BH   000014H   BYTE   UNIT     DATA           _DATA_GROUP_
    000020H.0 000021H.0 000001H.1 BIT    UNIT     BIT            _BIT_GROUP_
    000022H   000121H   000100H   BYTE   UNIT     EDATA          ?STACK
    FF0000H   FF0002H   000003H   ---    OFFS..   CODE           ?CO?START251?3
    FF0003H   FF0018H   000016H   BYTE   INBLOCK  CODE           ?PR?MAIN?MAPTEST2
    FF0019H      FF0029H       000011H       BYTE       UNIT         CODE           ?CO?MAPTEST2
    FF002AH   FF00E5H   0000BCH   BYTE   UNIT      CODE              ?C_C51STARTUP
    FF00E6H   FF043DH   000358H   BYTE   UNIT     CODE           ?PR?PRINTF?PRINTF
    FF043EH   FF043EH   000001H   BYTE   UNIT     CODE           ?C_INITSEG
    FF043FH   FF0474H   000036H   BYTE   UNIT     CODE           ?C?LIB_CODE
    FF0475H   FF049BH   000027H   BYTE   UNIT     CODE           ?PR?PUTCHAR?PUTCHAR
    Based in your code example, the ?CO?MAPTEST2 are all the literal strings used in the program, if you add a puts or another printf you will see the increasing of this segment.
    The NumConst will be displayed in the symbol table, Ex.:
    SYMBOL TABLE OF MODULE:  C:\EMBEDDED\EMUL251\MAPTEST (MAPTEST2)
          VALUE       REP       CLASS    TYPE      SYMBOL NAME
          ---         MODULE    ---      ---       MAPTEST2
          00FF0003H   PUBLIC    CODE     ---       MAIN
          00FF0003H   BLOCK     CODE     ---       LVL=0
          00FF0028H       SYMBOL     CODE       WORD         NumConst
          00FF0003H   LINE      CODE     ---       #3
          00FF0003H   LINE      CODE     ---       #4
          00FF0003H   LINE      CODE     ---       #7
          00FF0018H   LINE      CODE     ---       #9
          ---         BLOCKEND  ---      ---       LVL=0
          ---         MODULE    ---      ---       ?C_START
          00FF0000H   PUBLIC    CODE     ---       ?C_STARTUP
          00FF0000H   BLOCK     CODE     NEAR LAB  LVL=0
          00FF002AH   BLOCK     CODE     NEAR LAB  LVL=0
          ---         MODULE    ---      ---       PRINTF
          00000008H   PUBLIC    DATA     ---       ?PRINTF?BYTE
          00000008H   PUBLIC    DATA     ---       ?SPRINTF?BYTE
          00000008H   PUBLIC    DATA     ---       ?_PRINTF?BYTE
          00000008H   PUBLIC    DATA     ---       ?_SPRINTF?BYTE
          00FF0151H   PUBLIC    CODE     ---       PRINTF
          00FF0148H   PUBLIC    CODE     ---       SPRINTF
          00FF014EH   PUBLIC    CODE     ---       _PRINTF
          00FF0145H   PUBLIC    CODE     ---       _SPRINTF
    The variable "NumConst" and the Literally string "NumConst = %u" are placed in the same memory locations ( code ) but in different places. ( There's no ?CO? segment for your variable ).
  • Actually, both the variable NumConst and the String Literal "NumConst = %u" seem to be placed into the same segment:
    The map for my original example shows the size of the ?CO? segment as 0x10 (16 bytes); that's 14 bytes for the string (including NUL terminator) plus 2 bytes for the int (not sure why yours comes to 0x11?).
    What I actually want to know is, how much room are all my string literals taking?
    It looks like I'd need to subtract the sizes of all the SYMBOLs in the segment - but where can I find that in the map?
  • The segment is the same, code segment ( ?CO? ) but, the variable NumCast is only in the symbol table. If you analyze the ?CO? segment, you will see everything that is declared in the code segment toguether with the literal strings.
    The ?CO?your_source_file_name is the Room size of all your string literal. ( strings used by printf, puts and so on )
  • The ?CO?your_source_file_name is the Room size of all your string literal.
    Not quite sure what you mean by, "Room size?"
    I think you are using L251, which might give more details, but with BL51 I can't see any way to tell from the mapfile how much of the ?CO?your_source_file_name segment is occupied by String Literals, and how much by "real" constants.
    Basically I need to cut down my code size, and I think that String Literals are a prime target; therefore, I need some easy way to confirm just how much code is being used by String Literals (rather than "real" constants, which must be retained).
  • Hummmm... unfortunately the ?CO?your_file_source_name is showing your literals and other "real" constants, I could not find a way to see only the literals.
    When I add another code variable to the source file, the length of ?CO?xxx increase.
    Yes, I was using L251 ( FF0000h ).
