Hi, I have an Infineon 515C start kit and want to know how to program the Keil monitor into the flash? The flash is blank and the 515 doesn't have a boot strap loader so how can it respond to the Phytec flasht.exe utility provided for programming the flash? Do I have to remove the flash and program it using a seperate flash programming tool? Thanks for your help. Mark.
If the flash realy blank, you have to remove the flash and program it using a seperate flash programming Tool. How do you detected that the flash is blank ? Are the flashtools still not working although the red jumper S2 is closed ? What for OS do you use ? Another way is to send the board back to phytec for repair. Stefan
