Keil MCB167-NET Board & Ethernet ...
Respectable colleagues,
does somebody have an Ethernet code example which is made to be stored and executed from the FLASH memory (not Keil sample for the Monitor in RAM provided on the Keil's CD) ?
I need to test only two simple tasks to check two way communication. For example to turn on / off one LED on the board and to read status of some port or a pin on the Keil MCB167-NET board.
Also, I need suggestions what I have to do (to write in the Visual Basic or in the Visual C++) from the PC side to make this test.
Thanks in advance.
With best regards,
Dragan Kujovic
