I want to put a copyright message into the ROM. How do I make the linker locate it immediately after the interrupt vectors? Thanx, Erik
Here is an example of placing the copyright in Main.c.
code char Copyright[] = "Copyright"; void main( void ) { code char *Dummy = Copyright; //this stops linking warnings }
Thanx, but how to do in a DOS command file ? in advance thanks, Erik
If you have uVision, it shows you the corresponding command line at the bottom of each options page; otherwise, you'll just have to read-up that manual. Have fun!
I forgot: uVision creates a .lnp linker command file. So you could do a "dummy" buid with uVision, and then keep the .lnp file for use in your MS-DOS build? Or just run uVision "non-interactively" from the command line to build your project?
