I get the error 231 ("redefinition" of mib_type ) with the compiler version 6.14 when I'try to compile the flollowing code: ---Header File-------- #define u unsigned typedef struct mib_data_st { u char x; u char y }mib_data_st; extern code char **mib_type[8]; extern code mib_data_st mib_data[8]; ---End of Header File--- ---C-File--- code char *mib_type0="\x1""* 0 Hz *"; code char *mib_type1="\x1""* 1 Hz *"; code char *mib_type2="\x1""* 2 Hz *"; code char *mib_type3="\x1""* 3 Hz *"; code char *mib_type4="\x1""* 4 Hz *"; code char *mib_type5="\x1""* 5 Hz *"; code char *mib_type6="\x1""* 6 Hz *"; code char *mib_type7="\x1""* 7 Hz *"; code char *mib_type8="\x1""* 8 Hz *"; code char **mib_type[8+1]={ &mib_type0, &mib_type1, &mib_type2, &mib_type3, &mib_type4, &mib_type5, &mib_type6, &mib_type7, &mib_type8 }; ---End of C-File--- This problem did not occur with the Version 6.10. Has everyone any idea??
I don't know if everyone has an idea, but here is mine. Use
typedef struct { u char x; u char y }mib_data_st;
typedef struct mib_data_st_tag { u char x; u char y }mib_data_st;
I'm surprised that v6.10 let you get away with it: ---Header File--------
