Hi, all I found there is likely a bug in keil c51's compiler(V6.02, Optimization Level = 8) When compile and link the following program lines:
#include <absacc.h> #include <reg52.h> #define ADDR201 XBYTE[0x8000] bdata unsigned char D201; sbit green = D201^2; void main(void) { while(1) { green = 1; ADDR201 = D201; green = 0; green = 1; ADDR201 = D201; } }
RSEG ?PR?main?TMAIN main: ; SOURCE LINE # 8 ; { ; SOURCE LINE # 9 ?C0001: ; while(1) ; SOURCE LINE # 10 ; { ; SOURCE LINE # 11 ; green = 1; ; SOURCE LINE # 12 SETB green ; ADDR201 = D201; ; SOURCE LINE # 13 MOV DPTR,#08000H MOV A,D201 MOVX @DPTR,A ; green = 0; ; SOURCE LINE # 14 CLR green ; green = 1; ; SOURCE LINE # 15 SETB green ; ADDR201 = D201; ; SOURCE LINE # 16 MOVX @DPTR,A ; } ; SOURCE LINE # 17 SJMP ?C0001 ; END OF main END
MOV A,D201
MOVX @DPTR,A
Hmmm, dunno if that would be considered a "bug". To me, D201's declaration deserves "volatile" qualifier. --Dan Henry
But Source Line #13 has already loaded D201 into A:
; SOURCE LINE # 13 MOV DPTR,#08000H MOV A,D201 MOVX @DPTR,A ; green = 0; ; SOURCE LINE # 14 CLR green ; green = 1; ; SOURCE LINE # 15 SETB green ; ADDR201 = D201; ; SOURCE LINE # 16 MOVX @DPTR,A ;A has not changed - it is still D201!
Thx very much.
