I am using a structure named my_struct which is to be declared as extern. struct my_struct{ int a; int b; }; struct my_struct first; struct my_struct second; How do I declare the structure in the main file and use the structures first and second as extern in the other c files of the same project.
Don't forget those <pre> and </pre> tags! all your files need to be able to "see" the structure type definition; only one file must actually define the variables (as it is the definition which allocates storage):
//main.h // Define the structure so that all files can "see" it struct my_struct { int a; int b; }; // Declare the externs extern struct my_struct first; extern struct my_struct second;
//main.c // The header is needed for the struct definition; // It doesn't hurt to include the externs, // and ensures that declarations & definitions match! #include main.h // Define the structures - this allocates storage struct my_struct first; struct my_struct second; etc
//other.c // Include struct definition & extern declarations #include main.h etc
