I am having trouble using the linker "L51.exe". I am trying to link several OBJ files. This is my command line. L51 @files TO PRO3MAIN.LNK RAMSIZE(256) What is wrong? It doesn't create the output file PRO3MAIN.LNK. I can inline the OBJ files on the command line but not all of the files or I get the same result. PLEASE HELP!!!!
The Macro Assembler and Utilities User's Guide 07.2000 (A51.pdf) shows the command line options as either:
BL51 [inputlist] [TO outputfile] [controls]
BL51 @commandfile
Thank you ... I was SO frustrated with the problem. But then I looked into the Examples Sub-Directory from c:\C51 and found the exact thing you are talking about. Thank you So much for your reply. A simple solution to a BIG Headache! It's forums like this that help us contractors stay alive. Jon
