Which OBJ File Format is Keil using ? OMF ? Thanks freudi
If is a 16 bit address, its code 83 Intel format. Should be described in the Utilities Users Guide.
Check http://www.keil.com/support/docs/93.htm. Jon
OMF51 Find the definition here: http://www.keil.com/download/dlf.asp?ID=omf51.zip
Thank you all I got a development kit for an RF-Scanner with some 8051 inside It inlcudes only objectfiles ( By you I know now it is OMF51 Format) I have linked it now and got some warnings (not errors) about unresolved external symbols. For example ?c?memset, but only in the obj-files if i use memset in my c-prog everything is fine ? I can run my program on friday to see if it is really a problem or not. Do you have any suggestions ? Thanks for your help freudi
