locate copyright
Using c51/a51/bl51 is there a simple way to guarantee that a copyright message will appear in the code memory immediately following the interrupt vectors?
in advance, thanks
  • Here is an example of placing the copyright in Main.c.
    code char Copyright[] = "Copyright";
    void main( void )
      code char *Dummy = Copyright; //this stops linking warnings
    Now tell the linker to locate all global CODE variables from MAIN to 0x100. Do this by adding ?CO?MAIN(0x100) to the OptionsForTarget/Bl51LocateTab/CodeLine.
  • How about the following assembly file?
    cseg at 100h
    COPYRIGHT:  DB   "Copyright (c) 2001 Keil Software, Inc.", 0
    end
    Jon
