How can I get uVision 1.32's .PRJ file work with uVision 2? Is there any way to reuse my old but working 1.32 projects? The HEX output of uVision 2 is not correct if I only add all source into a new project. Thanks.
It's not very helpful to just ask "how do I make it work?" and say "HEX output of uVision 2 is not correct" Precisely what problems are you having with it "not working?" What messages are you getting? Which particular version of uVision2 are you using? What operating system & version are you running on? Specifically what is "incorrect" about the Hex file? Try these: UV2: IMPORTING A MICROVISION 1 PROJECT INTO UVISION2 V2.04 http://www.keil.com/support/docs/1255.htm UV2: CHANGING FILE PATHS IN A PROJECT AFTER IMPORTING http://www.keil.com/support/docs/1318.htm
