bootload.zip from Keil
I have downloaded bootload.zip from this homepage. There are 2 uV1 projects. In the abstract information is given the following advice:
"To test the WHOLE program with dScope, load EXT as an OMF file. Then, load BOOT as a .HEX file. Set a breakpoint at 0x8000 and hit GO."
I have imported the 2 projects to uV2. I think if I hit the debug button in the EXT project an OMF will be automatically loaded? How do I load the Boot.hex file in the debugger?
Thanks and regards
Karlheinz
