Running Debugger USB-FX2 Board Dev_IO Example
Tried to follow the Debugger example v_IO code,(Using the uV2 evaluation copy) for Cypress FX2. However, the instruction seem to be wrong and I haven't been able to debug using the serial port. Has anyone else seen this problem? NOTE: I am only working in Full Speed mode.
  • What do you mean, "the instruction seem to be wrong?"
    Do you mean the compiler seems to be generating invalid code?
    In what way does it seem to be "wrong?"
    Precisely what problems do you experience when you try to debug?
