What C51 needs really bad is ...
Inline assembly!
asm {
;you assembly code goes here.
My version is so out of date, tho, it may already support it and I don't even know.
  • What version do you have?
    It's been available since at least v6.03!
  • Actually, inline assembly has been available since before version 4.
    Take a look at #pragma asm, #pragma endasm, and #pragma src in the C51 user's guilde.
    Jon
  • The REAL method, not the .SRC workaround, where is it documented?, my manual document the .SRC.
  • Not sure what you're getting at there, Erik?
    Keil, in common with some other compiler writers, have chosen to implement inline assembler via .SRC and the Assembler.
    But isn't it fun, anyway!?
  • I guess the REAL questions is "How does the Keil C51 compiler generate an OBJ file?".
    Many C compilers generate assembler output that must then be assembled with an assembler. This is a 2-step process that requires running the C compiler and then the assembler.
    Many C compilers make this transparent and run the assembler for you (without you knowing it).
    The KEIL C compiler generates the .OBJ file without calling or running the assembler. Therefore, when you include in-line assembly statements, we chose to simply generate a .SRC file and let you assemble it. The rationale behind that is that if you are generating assembler code from the compiler, you are probably going to want to hand tweak it somewhat.
    Jon
  • >The KEIL C compiler generates the .OBJ
    Can you say that this 2 ways always produce the same .OBJ:
    1) .C --> .OBJ
    2) .C --> .SRC --> .OBJ
    in case of no using any #pragma asm/endasm ?
  • Can you say that this 2 ways always produce the same .OBJ:
    1) .C --> .OBJ
    Method (2) means that you have to call both C51.exe and A51.exe separately, so you'd have to ensure that all your command-line options matched precisely
    Also, I'm not sure whether C51 disables all optimisation when generating .SRC?
    (this could make sense, given Jon's earlier comments about "tweakability")
    1) .C --> .OBJ
    1 != 2.
    There are several reasons why.
    1. When you compile a C file and generate an OBJ file, the compiler injects debug information into the OBJ file. Things like line number-address offsets are included. When you compile a file with SRC and then assemble the SRC file, the object file has debug information from the assembler, and the line numbers refer to the SRC file (not the C file).
    2. When you compile a C file and generate an OBJ file, the C compiler includes references to the standard C library files (C51S, C51C, or C51L). When you create a SRC file, these references are not included. So, if you have a 1-file project that is compiled as a SRC file, you'll have to include the C libraries manually.
    3. When you create a SRC file, most optimizations are disabled to about side-effects that interfere with your in-line assembly. Additionally, the compiler attempts to color registers and doesn't "know" about the in-line code that you enter. That text is passed verbatim to the SRC file for assembly by the assembler. Ergo, the compiler can't make rational decisions about the in-line code you have.
    Jon
