Memory class question
I am using a Temic 80251 which gives me 1K on board RAM. Is there any
way that I can tell the compiler that the IDATA class is bigger than 256 bytes..
because I get an error from the compiler that I have exceeded capacity.
Or should I just use the edata class and just watch that I don't allocate
above the 1K limit???
Any suggestions appreciated.
Thank, Jim
  • The 1K of internal memory is not idata. idata is the same as the standard 8051 definition. Outside of the 1K internal, access is through the edata segment.
    You can access the internal 1K segment by defining it as xdata, and providing a data range in the linker.
    We put the following defines in a model.h, and include it in all source. This allows us to select which physical memory segment we want to place the data into.
            #define HUGE    huge        /* 16 Meg indirect addressing, full access */
            #define FAR     far         /* 16 Meg indirect addressing, in page */
            #define NEAR    near        /* 64k direct and indirect addressing */
            #define DATA    near        /* On-chip data */
            #define XDATA   near        /* was far  */
            #define FXDATA  xdata       /*  */
            #define PDATA               /* Paged xdata */
            #define CODE    far         /*  */
            #define IDATA   idata       /*  */
            #define BDATA   bdata       /* Bit addressable memory */
            #define EBDATA  ebdata      /* Extended bit addressable memory */
            #define SBIT    sbit
            #define BIT     bit
    As an example we would have:
    char  XDATA  value1;     // this goes in edata (near)
    char  FXDATA value2;     // this goes in 1K segment (xdata)
    The linker must be told where the xdata & edata segments are located.
    this is done using the class command :
    CL (XDATA (100h-41fh),                          &
        EDATA (8000h-0ffffh),hdata(8000h-0ffffh),   &
        ECODE  (0fe0000h-0feffffh),                 &
        HCONST (0fe0000h-0feffffh),                 &
        ECODE  (0ff2080h-0ffffffh),                 &
        HCONST (0ff2080h-0ffffffh) )                &
    When the code is compiled and linked, the variables will be placed in the respective memory spaces. By changing the defines and modifying the linker classes, you can assign any variable to any data space until you run out of memory. The linker file assignments above are what we use in our application. You have to define yours as needed.
  • Actually, using XDATA on the 251 forced the compiler and linker to use the MOVX instruction and to use the DPTR. These are horribly inefficient on the 251.
    You can use the on-chip 1K as NEAR (or EDATA) memory by declaring the variables as NEAR or by using the XTINY or the XSMALL memory models.
    Jon
  • Thanks Tom
    Excellent explaination
    Jim
  • Is it possible to place some critical variables, as near memory type, in the on-chip 1K memory, yet other non-critical variables, still declared as near memory type, in the external memory? In other words, how do you explicitly place two variables, both declared as near, into two seperate memory spaces - on-chip 1k and external memory?
