struct structSeperate { unsigned char uaHigh; unsigned char uaLow; }; union OneIntorTwoBytes { unsigned int un; struct structSeperate ua; }; void AFunction() { OneIntorTwoBytes unionMy; ... ...unionMy...// ... } In the above example, Could you please explain how many bytes of free mem will be allocated for AFunction()? How many bytes of free mem will be allocated for the whole module?
The unionMy variable (which is a union) will take 2 bytes. I don't know how much space is used by your function. Jon
Don't forget those <pre> and </pre> tags! This is a popular way to access individual bytes of a larger data type, but don't forget that it's non-portable - as it relies entirely upon the byte ordering of the Compiler/Target. There may also be alignment issues with some larger data types. You might want to try something like:
struct structSeperate { #if defined __C51__ unsigned char uaHigh; unsigned char uaLow; #elif defined SOME_OTHER_COMPILER unsigned char uaLow; unsigned char uaHigh; #else #error Unknown byte ordering #endif }; union OneIntorTwoBytes { unsigned int un; struct structSeperate ua; };
The only time a Union (or struct) will "cost" you extra memory beyond the size of its contents is if the compiler inserts any extra "padding" bytes for alignment. AFAIK, Keil C51, being targetted on an 8-bit architecture, doesn't add padding. Padding is usually only added on larger word-size machines, which don't like objects crossing word boundaries; eg, 16-bit objects starting on odd addresses for 16- or 32-bit machines; 32-bit objects starting on non-multiple-of-4 addresses on 32-bit machines. There is usually some sort of "pack" option to overrinde the padding, at the cost of access efficiency.
