finding recursive calls
Has anyone written a tool to help track down recursive function calls? I'm sure many of us have seen the dreaded C51 linker warning above recursive calls.
My problem: I just spent 30 minutes sifting through someone elses code trying to find the actual culprit that produced the recursive call linker warning (no function pointers in the code, so I was pretty sure the warning was real). It turned out to be about 4 or 5 function calls deep pass the function it warned about. Not a difficult task to do by hand, but....
I'm sure that the map file can be used to create a call tree, but I believe you'd have to create the call tree manually. It seems that that it wouldn't be that difficult to write a program that will parse the map file and tell you all the functions involved in a specified recursively called function. If it doesn't exist, maybe I'll be bored enough to actually write it someday :)
-nelson
  • What about the call/caller trees in the uVision Browser?
    There are plenty of "reverse engineering" tools on the market which will "map" your code - I think StarBase (formerly Premia, the makers of CodeWright) do one?
  • Source Browser in uVision2 have a bug:
    - when select function in Left window,
    and switch to "Call Graph" mode,
    then in Right window instead
    of full "call tree" only last
    sub-tree for each function displayed.
    This is for Keil C51 v6.12 (uVision v2.12),
    but I think the same problem in v6.14.
    Who know about C51 v6.14 (uVision2 v2.14) ?
  • Yes, I think you're right. :-(
    Can you get your code to compile in MSVC, and use the Browser there?
    What about the "call trees" shown in the Linker's Overlay Map in the mapfile?
    I'm still using uVision 1.32, and probably won't be switching soon (legacy code work). I didn't think uV2 would have that feature, so I forgot to mention what version I was using.
    Hmmmm... maybe one of the many CodeWright features I still have to learn? I just started using CodeWright about 2 or 3 weeks ago, and still have lots to learn.
  • >Can you get your code to compile in MSVC, and use the Browser there?
    Yes, MSVC Browser show call tree,
    and recursion looks like:
    test_1()
      |--test_2()
            |-- test_1()
                  |-- test_2()
                       etc...
    Yes, it work.
    But this is not the same as "visual tree", user forced to study linear represantation of tree.
    I think, Keil can:
    - fix a bug in Source Browser
    - add some features to print call tree
    - add some features for easy navigating via call tree
    and all be Ok.
