hi, i am using uVision2 V2.03 with PC Lint. does anybody know how to set up uVision2 to get the messages from Lint into a text file as well as into the build window. I'd appreciate any form of help or comment. Thanks in advance!
Take a look in the following support database. http://www.keil.com/support/docs/1835.htm
You can direct uVision to record everything from the Build window to a logfile by specifying "-o filename" on the command line See the "Getting Started" guide; it's Chapter 12 in the 8051 version, GS51.pdf
