I've just started using uv2. I want to import my assembly code into C source (inline or to link them whith C files) Thanks.
Check the following URL: http://www.keil.com/support/docs/1277.htm Jon
"I've just started using uv2." An ideal time to read the manuals! Start by going to the 'Books' tab in the uVision Project window, and open the uVision2 Getting Started Guide (GS51.pdf). Work through the example projects in chapter 7.
