Interface extern EEPROM over SPI Interface
Hi
I want to interface a serial EEPROM over the SPI Interface to an
Atmel 89S53. Does anybody have some Source Code to do this. My
doesn't work! For the EEPROm I have first to transmit the write enable
instruction and after that the write command the address and the data.
In my Code the Clock stops after every Byte. This is wrong. Why does
this happen?
Thanks for help
Christian
