Correction on "structs as return values"
From a previous thread:
"How the compiler implements this facet {stucts as return values} of ANSI C is of no concern to me unless I'm worried about efficiency."
Reply:
Great, another wrong sweeping statement.
I would post a counter example, but I already did in the thread "Problem with structs as return values". Of course, if one believes 3 equals to 4 then my counter example fails.
For those of you who do not believe 3 equals to 4, you must accept the fact that there are times you have to worry about Keil deviation from the ANSI C standard with respect to stucts as return values.
