i know this is not the right place but, maybe someone can help. i like to use MiniMon works fine but it won't accept any flash driver. when i declar a segment as type FLASH and add a driver function plus the drivers path, after choseing OK the Path is gone and if i try to execute the Flash command Minimon exits with "Path not Found" Does anyone know what i'm doing wrong? Any help would be great! Kai
