How to use ADuC812 SPI
Hello!
I tried to use the on-board SPI of the Analog Devices ADuC812
but I didn't managed it to work. No Data, no SCLK, the Pins
seemed all to be dead at all.
Maybe one of you can give me a hint or working sample code.
Thanks.
Here's some of my code:
// Initialize the SPI Interface
SPICON = 0x37;// configure SPI port for: 0011,0111 = 0x37
// Fosc/64, CPHA=1, CPOL=0, master
IE2 = 0x01; // enable SPI interrupt
EA = 1; // enable interrupts
void send_SPI(unsigned int byte)
SPIDAT = byte; // trigger data transfer
  • We are developing a project with ADuC812 in Federal University of Campina
    Grande, and I wish to communicate two microconverters using the SPI. I have
    some problems becouse with the flag ISPI becouse the flag don't change in
    the
    end of the transmission. Is necessary to use any interrupt routine for to
    use
    the flag ISPI? I need more information about this problem. I am sending my
    code
    used for transmit a caracter C and to monitore the change in flag ISPI. I
    noted
    that the flag don't change. Please look my code, is it wrong?
    Send me some information, and if possible change the code.
    If possible, answer me how I may to transmit a byte in a master(
    micriconverter) for a slave(microconverter).
    Sincerely,
    Jaidilson Jó.
    //Master
    #include <aduc812.h>
    #include <stdio.h>
    #define SPICON_MR 0x33
    sbit P3_5 = 0xB5;
    sbit P3_4 = 0xB4;
    int i;
    void main ()
    P3_5 = 1;
    // Serial
    SCON = 0x50;
    TMOD = 0x20;
    TR1 = 1;
    TH1 = 0xFD;
    IE2 = 0x01;
    IE = 0x81;
    TCON = 0x01;
    IT0 = 1;
    SPICON = SPICON_MR;
    P3_5 = 0;
    P3_4 = 0;
    SPIDAT = 'C'; //writing a character C for to transmit
    while((SPICON & 0x80) == 0)
    TI=0;
    SBUF='\n';
    while(TI != 1){}
    printf("%\n",SPICON);
    while(TI!=1) { }
    TI=0;
    SBUF='\n';
    while(TI != 1){}
    while(TI!=1) { }
    P3_4 = 1;
    P3_5 = 1;
  • Hello André,
    I'm using the ADuC834, but I expect, that the configuration and usage of the SPI is the same as for the ADuC812.
    Your initialisation seems to be o.k. - just take care, that the clock, polarity and phase settings match the requirements of your slave device. For the following SPI routine, you will not need to enable the interrupt. The routine can be used for sending and reading bytes. To read a byte just send a dummy character.
    UI8 SPI_char( const UI8 c )
        ISPI = 0;
        SPIDAT = c;
        while( !ISPI )
            ; // do nothing but wait
        return( SPIDAT );
    Hope this helps,
    Tim
  • Hello all,
    I put your code in my aplication:
    #include <stdio.h> // declarations for I/O functions
    #include <ADuC812.h> // 8052 & ADuC812 predefined symbols
    // Variables globales
    bit flag_int=0; // Flag de la interrupcion
    unsigned char dato=0;
    sbit SS = P3^5; /* SFR for P3.5 */
    // Prototipos de funciones
    void spiTx(unsigned char txDat); // Transmit a byte data over the SPI
    unsigned char SPI_char( unsigned char c );
    //___________________________________________________________________
    // INTERRUPT SERVICE ROUTINE
    void spi_int () interrupt 7 { // ISPI*8+3 = 59dec = 3bhex = ISPI
    SS= 1; // complement SS (P3.5 on eval bd.)
    dato=dato+1;
    /* END OF INT0 INTERRUPT ROUTINE */
    void int0_int () interrupt 0 { // int0*8+3 = 0dec = 3hex = IE0
    flag_int=1; // Flag de detección INT0 externa
    P3 ^= 0x10; // complement LED (P3.4 on eval bd.)
    dato=dato+1;
    // MAIN PROGRAM
    void main (void)
    /* CONFIGURE SPI */
    /* SPICON */
    SPE = 1; // SPI interface enable
    SPIM = 1; // SPI master mode operation
    CPOL = 0; // SPI CLOCK idles High
    CPHA = 0; // SPI leading SCLOCK edge to transmit data
    SPR1 = 1; // SPI clock rate SPR1 0 SPR0 0 for Fosc/4
    SPR0 = 1;
    /* CONFIGURACION DE LAS INTERRUPCIONES */
    EX0=1; // 1.- Habilitación Interrupcion externa 0
    PX0=1; // 2.- Interrupción externa 0 de alta prioridad
    IT0=1; // 3.- Interrupción externa 0 activa por flanco de bajada
    IE2=1; // Interrupcion Interrupcion SPI de fin de transmision
    EA=1; // Se permiten todas las interrupciones anteriormente programadas
    /* WAIT FOR INTERRUPTS */
    while (1)
    // while (flag_int)
    // spiTx(dato); // Manda dato por SPI
    SPI_char(2);
    // flag_int=0; // Restauro el flag de la interrupcion
    } // endless loop
    void spiTx(unsigned char txDat) // Transmit a byte data over the SPI
    ISPI = 0; // Clear ISPI bit
    SS=0;
    SPIDAT = txDat;
    while(!ISPI); // Wait until tx complete
    ISPI = 0;
    SS=0;
    SPIDAT = c;
    while( !ISPI )
    return( SPIDAT );
    I able to program clock and togle a port(I saw in osciloscope) but data does not flow thought MOSI line...
    Can anybody help me?
