Can you tell me : If an interrupt routine using (say) registerbank 2 calls a subroutine, does the subroutine have to be specified as using registerbank 2 as well? If so, what is the best way of specifying a routine that may be called from both the foreground and an interrupt?
In C51 there is a way to tell the compiler to generate register bank independent code for a given function. Then you could call such a function from either an ISR or mainline code using the normal cautions of course. Without this, you must call functions in the same register bank. - Mark
Yes, if the registerbank is different your data will almost definately get corrupted at some point. The method i have used is to declare #pragma registerbank ( ? ) at the start of a file that then only contaians the functions for that registerbank ( including the interrupt ).
NOAREGS
