Respectable colleagues, how to read a value of a BIT from value of a BYTE variable in Keil C ? For example: X=(Byte1.Bit7*4)+(Byte1.Bit6*2) Thanks in advance. With best regards, Dragan Kujovic
In C51, you'd have to go via a bit-addressable object; ie, 1. Copy your byte to a bit-addressable byte 2. Access the required bit 3. If required, write back to your original byte. Beware the optimiser! Failing that, the normal 'C' tools of masks/shifts, or bitfields - taking care to read the manual & app notes on bit & byte ordering.
Accessing an individual bit in a word. The first method is to use a mask to extract the value of a bit as in:
msb = ( byte & 0x80 ) != 0x00;
unsigned char mask_table[] = { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 }; bit_n = ( byte & mask_table[ n ] ) != 0x00;
struct { bit_0:1 bit_1:1 bit_2:1 bit_3:1 bit_4:1 bit_5:1 bit_6:1 bit_7:1 } byte; bit = byte.bit_7
> unsigned char mask_table[] = { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 }; > bit_n = ( byte & mask_table[ n ] ) != 0x00; Thanks, that's it. > Keil C51 has its own special extensions to take advantage of the C51 chip's bit addressing instructions. I don't know why Keil didn't make possible accessing individual pins on C16x, but I have made Reg167.h, Reg168.h, Reg169.h and RegST10F269.h files of my own with all necessary declarations. So, now is possible to access individual pins from C code with simple commands like: P2_0 = 1; // Port 2 Pin 0 HIGH or P2_0 = 0; // Port 2 Pin 0 LOW I will send those files to them, and if they find this useful, they can include those files in the software package, or put on the Web site. With best regards, Dragan Kujovic
// main.h #define OUTPUT 1 #define INPUT 0 #define HIGH 1 #define LOW 0 sfrbit P_TEST _atbit(P2,10); sfrbit DP_TEST _atbit(DP2,10); //main.c DP_TEST = OUTPUT; P_TEST = HIGH; _nop(); P_TEST = LOW; DP_TEST = INPUT; if (P_TEST == HIGH) { } Does this workout for you ? Best Regards, Bert
Don't forget those <pre> and </pre> tags when posting code: // main.h
void main( void ) { DP_TEST = OUTPUT; P_TEST = HIGH; _nop(); P_TEST = LOW; DP_TEST = INPUT; if (P_TEST == HIGH) { /* do stuff */ } }
You need to create your variable in BDATA zone and defined its bits : char bdata BYTE; sbit Bit0 = BYTE ^ 0; sbit Bit1 = BYTE ^ 1; sbit Bit2 = BYTE ^ 2; sbit Bit3 = BYTE ^ 3; sbit Bit4 = BYTE ^ 4; sbit Bit5 = BYTE ^ 5; sbit Bit6 = BYTE ^ 6; sbit Bit7 = BYTE ^ 7; Then you'll be able to access each bit individually. nb:you need to use a type cast (int) to multiply a bit by a number int X=(int)Bit7*4 + (int)Bit6*2; Gilles
