Anybody tried the latest release of uVision with Win98? I found that you can not remove files from a project once you have added them. You just get a msg box asking if your sure that you want to remove the file, but the file remains regardless of whether you click yes or no??? Posted this to Keil Support a week ago and haven't got a reply yet.
See the thread "The C51 v6.12 has errors!" http://www.keil.com/forum/msgpage.asp?MsgID=1846 It's about exactly the same thing! It might help if people used more descriptive titles to their posts? ;-) Jon Ward from Keil US concludes, "We have confirmed this problem and it will be corrected in the next C51 release."
This should not be a serious issue since projects always grow larger. It would be a show stopper if we couldn't add files.
This should not be a serious issue since projects always grow larger. It would be a show stopper if we couldn't add files. Actually, long, long ago, we offered that feature. :-) The IDE was limited to 500 source files (or something like that) and we had NUMEROUS users who exceeded that limit! :-( Jon
Thats true also with Win NT and µVision 2 V2.12 (is it the same version?) bye - Peter
Thats true also with Win95. Version number is µVision2 V2.12. a way to avoid bug : use DEL keypad on keyboard instead of right clic pop-up menu. Other bugs are : - button ABORT when you close a file without saving doesn't abort operation and close file with loosing your changes !!! - S166.DLL bug in MONITOR - RUNNING and trying to view a file (in woorkbook mode) !! Gilles
