Using DaVE 2.0 and uVision 2.02, I'm not having any problems getting small programs into a .H86 file to flash over onto the Phytec KITCON-167 board. The problem shows up in slightly more complex and larger programs. Can someone please walk me through what settings I need in Project -> Options for Target ? Current .H86 files don't work as intended. Thanks a bunch! PS: Is there a tutorial somewhere? I wasn't impressed with the Hands-On-Tutorial provided with the Phytec Eval Board.
"The problem shows up in slightly more complex and larger programs." Do you have an Eval version? Are you hitting the codesize limit? - just an idea.
Check the "Start*.a*" file.
