How to enable nesting comments
Hello Forum,
I wanna use nesting comments with µvision/C166. How to enable them? It is really annoying to work without them.
Thanks - Peter
N.B.: Nesting comments means something like this:
/* bla bla /* This is bla */
blub blub */
All of this is a comment. Without nesting comments the comment would end just before "blub blub" and the second "*/" would end up with an error.
  • Have you been worked with this kind of comments ? What tool could you use it without problems ?
  • I used it with SAS/C and some Win-based Compiler we used at our university.
    I know, it isn't Ansi compliant, but there are som compiler (preprocessor) options to enable this style of comments.
    bye
  • I couldn't find a specific directive Peter, you can cheat and change even the character that'll be used as a comment for example.
    /* traditional comment */
    >>>> cheat comment <<<<
    I cannot found a preprocessor directive. I think that the algorithm used to find comments don't allow this kind of nesting. If the algorithm finds /* he will only stop to set the text as a comment if it finds a */ character.
  • Many compilers support such nesting of comments, and usually have an option to enable or disable it.
    Probably, the facility is more common in "bigger" compilers; eg MSVC, BCB.
    C51 doesn't support it, either. :-(
    Perhaps you could try using the Borland or MS preprocessor, and compile the result with C166.
    A common reason for using it is when commening-out a block of code; eg,
    /* disabled code
       x = 1;         /* Blah   */
       y = 2;         /* Waffle */
       z = f( x, y ); /* Tripe  */
    In this case, an alternative could be:
    #if 0
       x = 1;         /* Blah   */
       y = 2;         /* Waffle */
    #endif
  • Thanks for the nesting comments example.
  • You can get very confused if you have a syntax-highlighting editor which handles nested comments in a slightly different way to your preprocessor!
    The safest (and ANSI-compliant) way is to avoid them!
  • Having said that, I have just noticed that there is a discrepancy between the way C51 and uVision handle adjacent comments.
    C51 regards the following as 2 separate comments, but uVision only colours the bold bit as a comment:
    /* Comment 1 *//* Comment 2
                     Comment 2 cont'd */
    It appears that uVision has taken the "//" as a C++ Style comment, without "realising" that it's actually the C-Style "*/" and "/*" comment delimiters "back-to-back"
