Does anyone know of any books in written english about C166 system design. I am interested in the hardware design and assembly level programming. Thank you in advance
Recently I have downloaded from there book, named 166des35.pdf about hardware design. Maybe some other books also exists there. Regards, Andrey
Andrew, Thank you for your reply. I should have mentioned the Hitex source in my original question. That is really the best source I have found to date. I currently have two C164CI boards in production, and I should give credit to Hitex support, even though I can't afford one of their emulators yet. I was hoping to find something more in depth, and hopefully a reference that covered the development toolchains. (Keil in particular). I highly reccomend that anyone starting a project using the C166 family avail themselve of the Hitex design document, it will save you a lot of headaches. I just wish Infineon and others could do as good a job of documenting their products as Hitex did. Eric
