Hi : I input a high signal (4V) from the output pin of 7832 (OR Gate) to the GPIO pin of 8051. I see the signal voltage is right on scope. But the fact is the 8051 can't receive this signal. Why ? Is the current too small to start the GPIO ? ps: the output pin of 7832 drive another two component. One is BJT,the other is LED. Thanks
Do you have the pin set as input (DDR set to 0) Does this pin have an alternative mode ? If possible, advertise the piece of code on the forum. (summary !!) Best regards ...
This condition is as below: I think the 8051 receivee the signal. But my camera can't work. I inspect the noise of ground. The noise is 500 mV. My camera's power supply is 3.3V. So .. Does anybody know whether it resulted the camera can't work ? Thanks
