Dears Programmers, I am looking to use the RTOS RTX51-TINY but the compiler don't find the corresponding library file. Ist this file include in the standard Keil software or did I buy a extension library?? Thanks for your precious help. Ludwig
Hi, if you are using uVision, the RTX51-TINY shows you where are the options to be set for compiling a RTX51-TINY-based program. anyway, the file you are looking for is in the c51\lib directory
RTX51 Tiny is part of the PK51 package. Do you have a PK51 package?
