An hour ago I installed the last version of this software, then I opened my project and added some files with extension "*.h" I opened them as "C Files", then when trying to close them one of them closed, but I cannot close the others (I opened three of them). I already re-started my computer but I just can't get these files off my project. I right click the mouse over the file select "remove filename.h" and asks If I am sure I want to remove it when I select yes, it does nothing!.
I thought the .h files are added when uVision scans for .h file dependencies found in your .c files. If you are including those .h files in one or more of the .c files in your project then you can't and shouldn't be able to remove them from the project. - Mark
This is, in fact, a very old bug! The 'Remove File' options on the 'Project' menu and the right-click popup menus have never worked! You have to select the file in the Project and press the 'Delete' button
Yes, that's generally true & normal practice, but there's no law that says you can't compile a file called 'fred.h' to 'fred.obj' In fact, the Triscend FastChip99 software generates a .h file which requires you to do this! You might also want to add a .h file to the Project just so that it's there in the Project window for quick access. In that case, you'd clear the 'Include in Build' and 'Always Build' options (or have a Group with those settings).
Hmmm. I just tried it (both the local menu and the Project menu) and was able to remove files from a project this way. I'm using Windows 2000, FYI. Does this fail to work, Andrew? Jon
Nope: neither the local menu nor the Project menu works! These are Dongled versions; Same effect (or rather non-effect!) under WinNT4 and Win98SE. Sorry, don't have access to Win2k.
I was able to remove the files the way Andrew indicated, with the "delete" key. This way worked properly. Luis A. Macias.
OK, We have confirmed this problem and it will be corrected in the next C51 release. Jon
Looks like C166 needs the fix, too: http://www.keil.com/forum/msgpage.asp?MsgID=1918 Will the ESC key be fixed, too: http://www.keil.com/forum/msgpage.asp?MsgID=1901
C51, C251, C166 all have this problem and are corrected in the next release. Just added the ESC problem to the list. Jon
