Addressing Problem?
I am a novice hobbyist trying to learn to learn how to program a microcontroller. I am using Keil C51 ver 6.10 and UV2.
After getting a project running, I read some application notes and decided that my code was not very professional (as expected) and tried to improve it. Now I can't get anything to work and I didn't save the working version.
Here is the manifistation of my problem:
A section of code calls a function that calculates a crc16 checksum passing two arguments -- a pointer to the message array and the length of the message.
When I single step through the code I see that the information passed over with the function call has arrived properly. Then, the first two lines of code in the function are supposed to initialize two local variables to 0xFF. These two local variables are stored in data memory at D:0x06 and D:0x07.
As I single step through the code, I note that the wrong memory locations are being written. After two steps, I have written 0xFF to memory locations D:0x0E and D:0x0F. That's an 8-byte offset!
Later in the code, I assign the value in these local variables to another variable array to be returned to the calling routine. Here, the correct addresses are being used -- D:0x06 and D:0x07.
To summarize:
uchCRCHi = 0xFF writes to address D:0x0F (expected D:0x07)
uchCRCLo = 0xFF writes to address D:0x0E (expected D:0x06)
uchCRC[0] = uchCRCHi assigns the value from D:0x07 (as expected)
uchCRC[1] = uchCRCLo assigns the value from D:0x06 (as expected)
What have I done wrong?
  • Did you declare the function with USING 1?
    D:0x07 is R7 and D:0x06 is R6. If you change the register bank to 1, the address for R6 is D:0x0E and for R7 is D:0x0F.
    Does this help???
    Jon
  • This looks prommissing! However, no, this function is not declared with USING 1. But the only way this function gets called is from within an ISR which is declared with USING 1. I'm at my day job now but when I get home this evening, I'll investigate along this line. Thanks.
    Well, that's the problem. In the ISR, the code switches to register bank 1 by changing the RB bits in the PSW. When the ISR calls your function, register bank 1 is still selected.
    If you will call this function from an interrupt, you must specify the NOAREGS directive.
    Jon
