loading 2 hex files into dscope
The design that I inherited incoporates two hex files. One is a bootloader that is located in the EPROM.
The other is an app loaded into external Flash.
The code will start in the bootloader and then jump to flash when a timer runs out.
EA is not toggled so the external code relies on the interrupt vectors in the bootloader.
Therefore, when I use dscope to debug the application I have to load both hex files.
I could get this to work in ds51 , but dscope dumps the previous load even though it doesn't
use the memory space.
