NT Driver Utility (Kernel Debugger)
I was trying to build a "Kernel Debugger" for a Printer Driver (under Windows NT ver.4.0).
Of course, before I would able to test my "Debugger" -- I have to compile it and link it to the
actual printer driver. Then execute the driver to see if my debugger does its task. The problem
arises when I used I/O functions (such as ZwCreateFile, ZwWriteFile, NtCreateFile, CloseHandle, etc.
especially C standard functions). Everytime I used such functions, the printer driver itself
could not able to print/generate output. Is it really possible to use file I/O functions when
designing a Kernel Debugger? If yes, why I encountered the said problem? -- is there any alternative
File I/O functions? If no, how could I possibly create a log file (since it is a required output
of my Kernel Debugger).
  • This is the wrong place for you question. Get a newsreader program and connect to a newsserver. Then go to
    news:comp.os.ms-windows.programmer.win32
    where your question will be more on topic.
    - Mark
