I must create a bootloader for C167CS for programming a flash memory using ASC0 and bootloader features. Where I found examples or source code for this programm? Thanks in advance.
You can find example code for a bootloader on the INFINEON microcontroller web site. Check out the applications area.
Download the followin PDF file from the infineon web site and take a look at the Bootstrap Loader section. http://www.infineon.com/cmc_upload/0/000/008/066/c167cr_um_v31.pdf Jon
