DW8051 MPAGE reg
The Synopsis DW8051 core uses a MPAGE sfr reg at 0x92 hex instead of the standard P2 register when accessing data with MOVX etc.
Do Keil support this register? If so what do I do to enable it?
Regards
Henrik
  • From the documentation that I have, it appears that the MPAGE register is only used if you do not include a P2 module in your Synopsis design.
    The MPAGE register provides the upper 8 bits for:
    movx a, @r0/@r1
    movx @r0/@r1, a
    In the C51 compiler, these instructions are used only in the COMPACT memory model (for PDATA variables).
    In the startup code, there is a section where you may set the value of P2 for all PDATA operations. Change this code to set the value in the MPAGE register.
    Jon
  • "In the C51 compiler, these instructions are used only in the COMPACT memory model (for PDATA variables)."
    Incorrect: the compiler must always use these instructions for any reference to PDATA - that's what PDATA means!
    The effect of the COMPACT memory model is simply to make PDATA the default - you can still explicitly define a variable to be in PDATA in any memory model you want (in fact, some contributors will urge that you should always do so!)
  • Good point. Thanks for clarifying that.
    What I meant was that MPAGE is only used when you use PDATA variables. PDATA is the default memory space in COMPACT model.
    Jon
