In trying to compile the following ( trivial to me) C code with the C51 compiler, I received error c213 "left side of asn-op not an lvalue" - " the address of a changeable object is required at the right side of the assignment operator". Code: unsigned int A[8]; unsigned int B[8]; unsignned int i; for (i = 0; i = 7; i++) A[i] = B[i]; /* error here */ Is it the compiler or the code??? Any help or comments appreciated. Thanks Andy
The following code seems to work OK:
void main (void) { unsigned int A[8]; unsigned int B[8]; unsigned int i; for (i = 0; i < 8; i++) { A[i] = B[i]; /* error here */ } }
unsignned int i
