Hi, Does anybody knows how to specify the memory map of the EZ-USB dev board ? I can't find it in the device list of uVision. I suppose that I get this message 'cause the linker thinks I have a standard 8051 with only 256bytes of on-chip RAM. Thanks, JP
The architecture of the 8051/52 dictates 128 or 256 bytes of IDATA max. If you have extra RAM on your chip, it's XDATA. Just use the xdata keyword to put variables out there.
