Hello! Can the hex2bin program be used for both, 8-bit and 16-bit hex files? Is there a good place to find definitions of Intel-Hex files? Thank you for any help! Holger
Take a look at http://www.speff.com Andreas
The Intel HEX file format is described on the Keil web site at: http://www.keil.com/support/docs/1584.htm HEX2BIN works with HEX, HEX86, and HEX386 files. http://www.keil.com/support/docs/274.htm Jon
