Size limit for single data-structure?
I seem to recall in the previous discussion forum there was a note relating to generating single, large, data-structures?
Is there a limit imposed by the C51 toolset on the size of a single data-structure?
Thanks,
Mark
  • Is there a limit imposed by the C51 toolset on the size of a single data-structure?
    Yes, there is a limit. You cannot create a structure that is larger than 64K. However, this is not REALLY a limitation since that is the limit of memory.
    Keil Support
