Hi all, I'm new to this Keil product [µVision] where can I learn C to write a program in µVision? regards, MB
It's basically ANSI/ISO C, with some extensions. For one, you must use sbit, sfr, or sfr16 to access bit, byte, or contiguous 2 byte registers in the 8051. You can disable integer promotion (a good thing) and enums only require 8 bits if they can fit in 8-bits, 16-bits otherwise. Functions are not reentrant by default. You must add the keyword 'reentrant' to functions that recurse or are truly reentrant. Interrupt Service Routines are declared as:
void isrUart(void) interrupt UART_VECT using REG_BANK_1 { // code }
Try Keil's reference 0-13-753815-4 Schultz C and the 8051
