I can't seem to make files other than *.a51, *.c to highlight comments and what not. Instead files such as *.asm are just solid black and white. I told the program it was an assembly file but it still displays it in black and white. Is there a way to make the uVision2 display different files extensions with colors?
Hmm... my uVision 2.05 shows .asm files properly syntaxed colored. I don't remember doing anything but checking "View->Options->Editor (tab)" to be sure that the "ASM Files" box is checked. I think you have to write the file to disk too.
If you look in the .opt file for a uVision2 Project, you will see: ### uVision2 Project, (C) Keil Software ### Do not modify ! cExt (*.c) aExt (*.a*; *.src) oExt (*.obj) lExt (*.lib) tExt (*.txt) pExt (*.plm) You may wish to take your life in your own hands, ignore the "Do Not Modify!" exhortation and try adding "; *.a51" within the parentheses for "aExt" If course, I'm just guessing here; I give *no* guarantee that this will not mess you up totally - let alone work! However, AT YOUR OWN RISK, it might be worth looking into. OR: you could just call your files ".a" or ".src" instead! ;-)
