2 dimentional arrays
Has anyone found a way to pass 2 dimentional arrays to a function? My arrays are stored in code and I need to pass them to a function to display them.
Gary Martin
  • Without testing, the code below should work:
    // Data
    int array2d[5][5];
    // Function Prototype
    void func(int ** pArray2d);
    // Main function
    void main(void)
    func(array2d);
    pArray2d[0][0] = 3;
    pArray2d[0][1] = 4; // etc...
  • You would thing so, but try doing with Keil.
    GAry Martin
  • Yes it should, but it dosen't.
    Gary Martin
  • Yes,
    Without testing, it works. But when tested it doesn't.
    is a function that expects pArray2d to be a pointer to a pointer to an int. This is NOT what is needed.
    This is one of the areas of C that most confuses people. In most contexts, the compiler converts a reference to an array into a pointer to the first element of the array. This leads people to think that arrays and pointers are equivalent. They aren't.
    In C, multi-dimensional arrays are implemented as arrays of arrays. So the first element of a two-dimensional array is a one-dimensional array. Therefore, a pointer to the first element of a two-dimensional array is a pointer to a one-dimensional array - not a pointer to a pointer.
    Here is a working example:
    unsigned char _2d_array [5][5];
    void func (unsigned char (*x)[5])
    x [0][0] = 1;
    x [1][0] = 6;
    x [2][1] = 12;
    void main (void)
    func (_2d_array);
    while (1);
    Note that func:
    is declared with an argument that is a pointer to an array of 5 items. This is required so that the compiler knows how to handle the multiple dimensions.
    The parentheses around *x are required. We want x to be a pointer to an array of 5 unsigned chars. Without the parentheses, the '[]' would take precedence over the '*', and x would be an array of 5 pointers to unsigned char.
    Hope this helps.
    Keil Support
