Does anyone out there have any example code for in-circuit programming a 29F010 flash? I plan to set up one sector as "unprotected" and use that to store configuration data which can be modified in the field without a prom burner. The rest of the chip will be set up as "protected" and will contain program code and will be programmed with a prom programmer and not available for field modification. I need a starting point and will appreciate any help you can provide.
The following has been used with the Keil MCB520 evaluation board. It might be useful for what you are trying. Keil Support
/* FMEM.C Routines to program the Intel 28F020/010 Flash Memory. */ #include <absacc.h> #include "mcb520.h" #include "fmem.h" #define CMD_READ_MEMORY 0x00 #define CMD_SETUP_ERASE 0x20 #define CMD_ERASE_VERIFY 0xA0 #define CMD_SETUP_PROGRAM 0x40 #define CMD_PROGRAM_VERIFY 0xC0 #define CMD_RESET 0xFF #define VPP_PORT (VPP_NOT_ENABLE) #define VPP_OK_PORT (VPP_NOT_OK) #define VPPH 0 #define VPPL 1 #define VPP_OK 0 #define MAX_ERASE_PLSCNT 3000 #define MAX_PROGRAM_PLSCNT 25 #define DELAY_US1 2UL #define DELAY_US6 (DELAY_US1 * 6UL) #define DELAY_US10 (DELAY_US1 * 10UL) #define DELAY_MS10 (DELAY_US10 * 1000UL) #define DELAY_MS1000 (DELAY_MS10 * 100UL) unsigned char flash_program ( unsigned long offset, unsigned char *buf, unsigned int buflen) { data volatile unsigned long i; data volatile unsigned int plscnt; /* quick pulse counter */ /*------------------------------------------------ Enable programming voltage and wait for it to stabalize. ------------------------------------------------*/ VPP_PORT = VPPH; /* set VPP HI */ VPP_OK_PORT = 1; /* enable input on VPP_OK_PORT */ for (i = 0L; i < DELAY_MS1000; i++) { if (VPP_OK_PORT != VPP_OK) /* if VPP is not good, continue */ continue; goto VPP_GOOD; /* if VPP is good, erase the FLASH */ } VPP_PORT = VPPL; /* set VPP LO */ return (FLASH_VPP_FAIL); /*------------------------------------------------ Loop thru the memory and program/verify each byte. ------------------------------------------------*/ VPP_GOOD: for (i = 0L; i < DELAY_US10; i++); /* delay for 10us */ for (i = 0L; i < DELAY_US10; i++); /* delay for 10us */ for (plscnt = 0; (plscnt < MAX_PROGRAM_PLSCNT) && (buflen != 0); ) { XBYTE [0] = CMD_SETUP_PROGRAM; XBYTE [offset] = *buf; /* program byte */ for (i = 0L; i < DELAY_US10; i++); /* delay for 10us */ XBYTE [0] = CMD_PROGRAM_VERIFY; if (XBYTE [0] != *buf) /* if byte is not programmed, try again */ { plscnt++; continue; } buflen--; buf++; offset++; } /*------------------------------------------------ Enable memory reads. ------------------------------------------------*/ XBYTE [0] = CMD_READ_MEMORY; /*------------------------------------------------ Disable programming voltage and wait for it to stabalize. ------------------------------------------------*/ VPP_PORT = VPPL; /* set VPP LO */ VPP_OK_PORT = 1; /* enable input on VPP_OK_PORT */ for (i = 0L; i < DELAY_MS1000; i++) { if (VPP_OK_PORT != VPP_OK) /* if VPP is good, continue */ break; } return ((plscnt >= MAX_PROGRAM_PLSCNT) ? FLASH_PROGRAM_FAIL : FLASH_OK); } static unsigned int flash_clear_block ( unsigned int plscnt) { data volatile unsigned long i; /* temp var */ data volatile unsigned long addr; /* address */ for (addr = 0L; (plscnt < MAX_PROGRAM_PLSCNT) && (addr < 0x00010000); ) { XBYTE [0] = CMD_SETUP_PROGRAM; XBYTE [addr & 0xFFFF] = 0; /* program 0 */ for (i = 0L; i < DELAY_US10; i++); /* delay for 10us */ XBYTE [0] = CMD_PROGRAM_VERIFY; if (XBYTE [0] != 0) /* if byte is not programmed, try again */ { plscnt++; continue; } addr++; } return (plscnt); } static unsigned int flash_erase_block ( unsigned int plscnt) { data volatile unsigned long i; /* temp var */ data volatile unsigned long addr; /* address */ for (addr = 0L; (plscnt < MAX_ERASE_PLSCNT) && (addr < 0x00010000); plscnt++) { XBYTE [0] = CMD_SETUP_ERASE; XBYTE [0] = CMD_SETUP_ERASE; for (i = 0L; i < DELAY_MS10; i++); /* delay for 10ms */ for (; addr < 0x00010000; addr++) { XBYTE [addr & 0xFFFF] = CMD_ERASE_VERIFY; for (i = 0L; i < DELAY_US6; i++); /* delay for 6us */ if (XBYTE [0] != 0xFF) /* if byte is not erased, try again */ break; } } return (plscnt); } /*------------------------------------------------------------------------------ unsigned char flash_erase (void); This function uses the Quick Erase algorithm presented in the Intel Flash Memory Vol 1 1995 data book. ------------------------------------------------------------------------------*/ unsigned char flash_erase (void) { data volatile unsigned long i; data volatile unsigned int plscnt; /* quick pulse counter */ data unsigned char retval; /*------------------------------------------------ Enable programming voltage and wait for it to stabalize. ------------------------------------------------*/ VPP_PORT = VPPH; /* set VPP HI */ VPP_OK_PORT = 1; /* enable input on VPP_OK_PORT */ for (i = 0L; i < DELAY_MS1000; i++) { if (VPP_OK_PORT != VPP_OK) /* if VPP is not good, continue */ continue; goto VPP_GOOD; /* if VPP is good, erase the FLASH */ } VPP_PORT = VPPL; /* set VPP LO */ return (FLASH_VPP_FAIL); /*------------------------------------------------ Loop thru the memory and program each byte to 0. ------------------------------------------------*/ VPP_GOOD: for (i = 0L; i < DELAY_US10; i++); /* delay for 10us */ for (i = 0L; i < DELAY_US10; i++); /* delay for 10us */ plscnt = 0; for (i = 0; i < 4; i++) { ROM_A17 = ((i & 0x02) ? 1 : 0); ROM_A16 = ((i & 0x01) ? 1 : 0); if ((plscnt = flash_clear_block (plscnt)) >= MAX_PROGRAM_PLSCNT) { retval = FLASH_CLEAR_FAIL; goto ERASE_EXIT; } } /*------------------------------------------------ Loop thru the memory and erase/verify each byte. ------------------------------------------------*/ plscnt = 0; for (i = 0; i < 4; i++) { ROM_A17 = ((i & 0x02) ? 1 : 0); ROM_A16 = ((i & 0x01) ? 1 : 0); if ((plscnt = flash_erase_block (plscnt)) >= MAX_ERASE_PLSCNT) { retval = FLASH_ERASE_FAIL; goto ERASE_EXIT; } } retval = FLASH_OK; /*------------------------------------------------ Enable memory reads. ------------------------------------------------*/ ERASE_EXIT: XBYTE [0] = CMD_READ_MEMORY; /*------------------------------------------------ Disable programming voltage and wait for it to stabalize. ------------------------------------------------*/ VPP_PORT = VPPL; /* set VPP LO */ VPP_OK_PORT = 1; /* enable input on VPP_OK_PORT */ for (i = 0L; i < DELAY_MS1000; i++) { if (VPP_OK_PORT != VPP_OK) /* if VPP is good, continue */ break; } return (retval); }
hi, one quiestions please, i have memory 29F010,read you solution , but i conect memory, used program universal??? please thank
"but i conect memory, used program universal???" Sorry - couldn't follow that. Please rephrase - what is your actual question?
"Does anyone out there have any example code for in-circuit programming a 29F010 flash?" Have you checked the manufacturer's website?
