uVision2 hangs directly after start. The main frame as well as the logo appears on the screen, but then the application is locked forever. I use Win NT 4.0 SP 6. This happens only when I am logged in as user. When I am logged in as admin, everything is fine. Best, Ernst Haselsteiner
It sounds like you may not have the permissions set correctly for one or more of the directories. Keil Support
Is Microsoft Outlook running? I find that sometimes this will prevent uVision from finish starting. Just kill Outlook and uVision will run as normal. - Mark
Not MS Outlook, but Lotus Notes is running and this seems to give the same problems as Outlook. Best, Ernst
