Here's an excerpt of my main module (the beginning of it): #include <ezusb.h> #include <ezregs.h> #include <tng.h> #include <string.h> #include "system.h" #include "lcd.h" #define IMG_SIZE (21*16) extern BYTE xdata DataBuf[]; volatile BYTE Display_Mode, LineCount, X_Offset, Row_Start = 0, GrabRequest, GrabOn, H_Bytes, Zoom_Value; DWORD j; BYTE i; WORD ill1=1500, ill2=1500; static xdata WORD k = 300; void ShowPicture(void) { ... ordinary functions and code I accidentally put a semicolon after "Row_Start = 0" when splitting the line for new variables. The module compiled fine, resulting to weird behavior. So, what exactly does the compiler do when encountering plain variable names on a line? I'm using KEIL V5.20 (DLL 1.32a). Thanks, Harri
C allows the type specifier to be omitted, in which case it defaults to "int". This means that your so-called "plain variables" are ints. --Dan Henry
IMO, this is a jolly good reason for *not* having multiple comma-separated variables declared together! It's safest to stick to one per line; eg: int a; int b; int c; rather than: int a, b, c;
