I'm doing an application containing some I2C code on a Infineon C161PI. When I put the I2C code into main, everything works alright. When I put it into a timer ISR, it works, too. But when I try to execute the I2C code (takes less than 1ms to execute) in the RTC ISR (called each second), the code doesn't work anymore. Any suggestions ? Michael
No I found the answer: The RTC was intialized and the ISR was called before the I2C was initialized. This caused the I2C to crash. After disabling the IEN before Project_Init manually, everything works alright.
